raphael_bellizzi
Flight distance : 757976 ft
Portugal
Sir Oliver Posted at 1-4 01:37
Hi,
I can also confirm this behavior (iphones 8 and 12 PM) and probably many others, as this issue has been reported many times in this forum. Specifically, it is related to panorama and FPV video modes (what I have noticed) . So when you switch from some other video mode (TiltLocked, Follow...) to Video FPV or Pano, horizontal level of the phone gets altered (disbalanced), usually in direction right-down (about 2-3°). If you go back, to any other mode, gimbal goes to balanced position. If you try this few times, notification pops up that phone is not balanced any more and that (re)calibration is needed (or something like that).
Exactly the same problem here, plus when I press the trigger twice the gimbal doesn't point straight forward. It stay pointed like 5 degrees do the left.
Also another problem. When your camera is pointed down or up and you make the tilt movement using your wrist or the joystick, the motors like gets like a physical conflict and wobble sideways for like a seconds.
Definitely a horrible product and it seems that they don't care to solve anything since they are not replying anything in this forum about the OM4 like they do on the professional forum (I have the RS2 and they admins try their best to solve all the problem) |
