guido's account
Flight distance : 325269 ft
DJI Wanda Posted at 2020-11-26 01:40
Hello there, thank you for your interest on the RavenEye. We do not recommend install the Ronin App on the Crystal as it only support DJI GO, DJI GO 4, and DJI Pilot. And the CrystalSky do not support the Bluetooth connection, the Ronin App will not able to connect with the gimbal.
Thanks.
Hi, when you connect reveneye by wifi, the app recommend to turn off Bluetooth in order to avoid interferences. So if you are using reveneye you can’t use the ronin app at the same time. So why don’t you recommend to install ronin app on cristalsky? The ideal of a field monitor from DJI ecosystem should be able to work with al least the pro items, as RS2 / Reveneye / Inspire 2 / Cristalsky, etc. |
