DJI Gamora
InsaneDiego Posted at 11-24 07:38
I got a set of ND filters. It didn't make a bit of difference. I think sharpness plays a part when you are rotating the craft and you have very fine detail, almost moire conditions. The bigger problem is the raising and lowering of the gimbal. It's like it adds digital noise and I don't see that in the Air 2. The condition only occurs when you move the gimbal up or down too quickly. You get that grainy haze over the image (that again, is really only obvious when you are looking in 4k and up close). The solution is to be slower on the movement of the gimbal. It has no issues if you hit the speed right. To help to that end, I've gone into the Gimbal settings and adjusted it so you can't move it quite as fast. I think the Cine is set for 10 degrees and Normal is 20. I did notice that my Air 2 had Normal set to 15! So I may lower the Normal even more if I see that I can't control the speed.
It's definitely not a deal-breaker on this model. It is, after all, 1/2 the cost of the Air 2. Since there is a pretty easy workaround, and again, only someone nitpicky like me would notice under the right conditions, this is a small compromise probably due to the smaller sensor and electronics on the craft.
Hello there InsaneDiego, sorry to keep you waiting. I receive a response from our designated team. Please be advised that what we can do is to set ISO to Auto and select Anti-Flicker to the corresponding frequency (50 Hz or 60 Hz). In Shutter Priority mode or Manual mode, manually adjust the shutter. Select 1/100S, 1/50S, or 1/25S for a 50 Hz light source. Select 1/120S, 1/60S, or 1/30S for a 60 Hz light source. If a concern occurs in a brighter or lighter environment when using Auto mode, the shutter will make automatic adjustments based on environmental lighting. Thank you for understanding and support. |
