Lets find the issue!
12Next >
1530 52 2020-11-17
Scarves UP
Flight distance : 372992 ft
Many like me are having numerous problems on 1.2.0 and later. Lets share about our devices and leys find the solution. Idea came from @GaryDoug.
Plz share the data: about if the app works and what device you're using and how much space there is on it. More info is always better as well!
2020-11-17
Scarves UP
Me: Samsung S9+  10gb space,  fly app 1.1.10 works
1.2.0 and newer doesnt.
2020-11-17
Scarves UP
No cached video.
I use a screen recording app, but it doesn't work without it either.
2020-11-17
jonny007
I had never installed a version higher than 1.1.8 and never had any errors, but due to the error message of the 1.2.x version I can also imagine that it could have something to do with wifi. So whether the band is 2.4 or 5.8 GHz and whether automatic channel selection or a fixed channel is set and if so, which one. Perhaps the error only occurs with certain channels or in a certain channel range.
2020-11-17
Scarves UP
jonny007 Posted at 11-17 12:04
I dont think so, the drone response was quick.
2020-11-17
Ph3onix
Flight distance : 2341886 ft
tested on xiaomi redmi note 8t, mi pad 4, asus zenpad 3s Z500 M with an average of 15 giga of free minimum none of the last two versions work correctly, version 1.1.10 and previous version work
2020-11-17
Scarves UP
Ph3onix Posted at 11-17 12:23
Thanks! Are they all supported? @GarDoug has an UNSUPPORTED device than works, maybe DJI wrote the list backwards.
2020-11-17
Ph3onix
Scarves UP Posted at 11-17 12:28
no, none are on their list. but they always work with the MM
2020-11-17
pagi_pl
Flight distance : 1414160 ft
Poland
Hi
Im android user of MA2.
I updated only RC to 02.00.1101 ver.
Apk ver - 1.1.10 (prev one)
RC ver - 02.00.1101
MA2 - 01.00.0340 (not updated to newest one)
Android 10 (Moto G8)
Yesterday 2h flight time. No problem notice with MA2.
2020-11-17
Scarves UP
Ph3onix Posted at 11-17 12:32
Thanks again!
2020-11-17
Scarves UP
pagi_pl Posted at 11-17 12:34
Hi
Ok, thanks! I think the issue is with the MM, not sure though. And also, the issue is with app update 1.2.0 and later. Thanks anyway!
2020-11-17
djiuser_RIeSM3mAo5mf
Flight distance : 542083 ft
Funny, they get the 500€, they dont make any Major upgrade since 9 months, and you request that we make the work for them...
2020-11-17
mark117h
Flight distance : 241306 ft
Hi Scarves UP.
I am curious to see what the results are and what kind of devices people are using with the DJI Fly app, whether on the compatible list or not.
I am currently running this version of the DJI Fly app on my NOKIA 6 TA-1033 phone, DJI Fly v1.2.1 (898-googleplay).
I have not had any of the major issues that others have been having, i did initially get a message pop up warning of interference before i took off when testing down near my mum's house but it was literally that quick i had to go and view it in my flight data center to see what the message actually was, my message did not did not stay there as others have reported though.
I am going to try in the next day or two with the weather permitting trying it out more extensively where i live as i have got industrial buildings and the like on one side and nothing but open farmers fields and wood's on the other side so it will be intresting to see how and what may happen.
I also use AZ Screen Recorder, although i do not use it that often as i have found that it can lag out my live video feed in the controller, although, i am also thinking of trying to get one of the phones in DJI's " Compatible List " that has got a lot more RAM and more Storage on the internal, only if i can find one cheap enough though as i am not in any chance going out and spending or laying down £800 on one, hell, i could get a Mavic Air 2 Fly More Combo for that price lol.
My current storage situation is that i have got 96GB Combined, but my current storage is at 36.16 GB, however, separately in the storage section my storage currently stands at.
Internal Storage = 29.78 GB Used Of 32 GB.
64GB SDXC Drive = 6.37 GB Used of 64.00 Gb.
NOKIA 6 TA-1033 full specifications (TA-1033)
5.5" FHD, 1920 x 1080 pixels.
16 MP. 4896 x 3264 pixels.
3 GB RAM.
32 GB Internal, Also using a 64GB SDCard as well.
7.1.1 Nougat --> 9.0 Pie.
3000 mAh. Li-Ion.
154 x 75.8 x 8.4 mm. 169 g.
Snapdragon 430 MSM8937.
Cheers & Peace Out
Mark
EDIT : Had to make a few minor adjustments.
2020-11-17
Ph3onix
the MM and already dead and buried for DJI we should no longer hope for anything for our MM unfortunately
2020-11-17
GaryDoug
Flight distance : 1264639 ft
I have two Mini's and use an unapproved device (Tab A) on one and an approved device (S6) on the other. I have no issues with either Mini.
Samsung Tab A SM-T290: Fly app 1.2.0, Android 10, 14gB out of 32gB storage used. 1.4gB out of 2.0 gB memory used. Security options are deactivated. No cell service, WiFi only. This device is too slow to be used on the MA2 or Mini 2.
Samsung S6:  Fly app: 1.2.1, Android 7, 17gB out of 32gB storage used,  2.1gB out of 3gB memory used. No SD card option. Security enabled. Cell service: T-Mobile
2020-11-17
ABeardedItalian
Flight distance : 1063107 ft
Make sure to check flight logs, my Fly App only reports verty few weak signal errors but my flight log shows an entirely different story.  I too was under the impression that everything was fine with my mini, no signal issues, video feed, nothing.
Will try like others and roll back and do some testing.
2020-11-18
klaatu barada
app version 1.1.8
HUAWEI MediaPad T5
HUAWEI P Smart
no issues
2020-11-18
Scarves UP
klaatu barada Posted at 11-18 05:31
app version 1.1.8
HUAWEI MediaPad T5
HUAWEI P Smart
Thanks! The issues came after 1.2.0!
2020-11-18
Scarves UP
ABeardedItalian Posted at 11-18 04:09
2020-11-18
Scarves UP
GaryDoug Posted at 11-17 15:46
Thanks Gary!
2020-11-18
Scarves UP
Ph3onix Posted at 11-17 14:46
I know! Just curious.
2020-11-18
Scarves UP
mark117h Posted at 11-17 14:40
Hi Scarves UP.
Thanks Mark! Im curious too!
2020-11-18
klaatu barada
Scarves UP Posted at 11-18 05:44
sorry bud...didn't read the title right
2020-11-18
Scarves UP
klaatu barada Posted at 11-18 07:26
No problem KB!
2020-11-18
Scarves UP
<1.1.10 works
>1.2.0 doesn't
Samsung S9+
3 apps running
Screen Recording on
Airplane mode off
Wifi off
Bluetooth off
Just more info
2020-11-18
Scarves UP
Pixel 3- no recorder, 5 apps open, 40 gb free space app 1.2.1 works
2020-11-22
JohnLietzke
Flight distance : 3125968 ft
As both orginal Mini and Air 2 users had problems with the DJI Fly v1.2.0 I thought this might be helpful.  I have a Mavic Air 2, IOS 14, iPhone 11, DJI Fly v1.2.1.
Everything for me worked perfectly with the exception of DJI Fly v1.2.0 and the first RC update to add the Mini 2 on 11/5. Both independently had lots of problems.  From what others are saying on here DJI resolved the Air 2, Mini 2 and original Mini issues in DJI Fly v1.2.1.
The problem seems to be related to DJI Fly v1.2.0 which is outdated, accross the spectrum of all the drones.  I personally think it was rushed out to add support for the Mini 2 with out signifcant testing.
2020-11-22
GaryDoug
If I can find the time, I will try to do a comparison test with my Mini this week. It is now  using 1.2.0 on an unapproved tablet. I will test the range it takes to lose comms. Then I will update to 1.2.1 and repeat the test over the same route. Disclaimer: There is a lot of WiFi interference in my area so the range will probably be small for both.
2020-11-22
Scarves UP
GaryDoug Posted at 11-22 20:11
Out of curiosity: how much range do you get in urban areas? I get about 4/5 - 1 mile in downtown Minnesota.
2020-11-23
Scarves UP
Thanks! Appreciate it! If only this rain would pass....
2020-11-23
Scarves UP
JohnLietzke Posted at 11-22 10:07
2020-11-23
ABeardedItalian
I need to do more testing before I have anything solid to report on, but early tests show that the app might just be more sensitive to report the warnings and not an actual signal issue.  I skipped 1.2.0 so I'll have to try it and see if it gets really bad, but when flying on 1.10 the video would get stutter and then proceed with warning at final distance but on 1.2.1 where the video would begin to chop up I get a warning now where before I never did. On 1.10 and 1.2.1 and litchi I get the same distance as before, the video only drops at 1100+ feet, I'll try with 1.2.0 and let you guy's know my findings later.
2020-11-23
Scarves UP
ABeardedItalian Posted at 11-23 06:07
Great! Thanks.
2020-11-23
DowntownRDB
Flight distance : 1722 ft
(On compatible list) Samsung S10+, Snapdragon 855 processor, Android 10 OS, 8GB RAM, 392 GB internal available, 312GB GB external available, Airplane mode enabled, no Apps running in background.
(Not on compatible list) Samsung Tab S6, Snapdragon 855 processor, Android 10 OS, 215GB internal available, 8GB Ram, 401GB external available, Airplane mode enabled, no Apps running in background.
DJI Fly App v1.2.1 (898-googleplay), no cached video (use AZ Recorder), WIFI band set to Auto, Sync Flight Data to Off (which is why my flight distance only shows inaugural flight info before I got security smart and turned data to off)
RC and MM are on most current firmware versions
I’m not experiencing any issues such as video feed, signal interference or disconnects.  Flights have been over water, in the country and in the city.  Confirmed no issues using flight logs also.  Only issues I had was on 1.2.0. which also affected my MA2.
2020-11-23
Scarves UP
DowntownRDB Posted at 11-23 06:35
Thanks DRDB!
2020-11-23
ABeardedItalian
double post.
2020-11-23
Scarves UP
2020-11-23
GaryDoug
Scarves UP Posted at 11-23 05:53
I haven't flown in any urban/city areas as of yet. I'm sorta suburban/country, but still densely populated. I think the farthest I got was about 1.2 miles over the Gulf but I turned back before signal was lost because I thought it was probably coming soon.
When I use a WiFi meter on my phone, the screen is flooded with a lot of stations.
2020-11-23
Scarves UP
GaryDoug Posted at 11-23 13:39
Got it. Thanks. The most ive ever gotten over a lake was 2.1 miles before i lost VLOS. The FCC Mm's range isnt that bad, its just the CE Mini.
2020-11-24
GaryDoug
Scarves UP Posted at 11-24 05:45
"2.1 miles before i lost VLOS"
Was that a typo? I can't imagine anyone except Superman being able to see that little drone from 2 miles away ;-)
2020-11-24
12Next >
