Huginn Kenningar
Flight distance : 49635259 ft
3Km away with tailwind and then 3Km against the wind it's just not possible with this drone... If you are over land you'll have to search the drone on the floor but over water...
On windy conditions (when you get those "high wind warnings") never fly away more than 500-1000 meters or so, and never fly away with a tailwind or you won't return home... Fly against the wind and return with the wind on your back, and allways start the return on green, never wait till the battery gets orange, specially when far away.
Only once I waited for the orange, had to face a front wind and returned home at 12% or so, never again. Allways return on green, land on 30-40% battery, the batteries will last longer and you have that 30-40% extra time to face any possible problem (except being attacked by a bird or similar).
Normal mode is more efficient than sports, only use sports if the wind is so strong that you cant fly or when you know you are going to arrive home no matter what. I usually engage sport mode to do the last Km to home, but at 2Km or so I use normal and cine.
The max range for the mini 2 without wind is about 8Km (4 to go, 4 to return), but it's not safe, you'll use the entire battery. 3km is the top "safe" distance without wind, but with strong wind never go further than 1Km, just take off closer to the location where you want to take photos/videos and you can work even with wind quite safely and easily.
Also, dont believe all what says UAV forecast or simmilar apps, they can say there's no wind and it is. If you think there's a lot of wind or if the drone is telling you that there's strong wind, believe the drone, not the apps.
PS: Sorry for the loss.
