Fat Panda
Flight distance : 31050 ft
It seems your understanding of their DJI Select has some problems. I'm a DJI select member too! You needed to purchase a machine first, then you are able to get the Member Purchase Eligibility, after getting the eligibility and purchased the DJI Select, then you will get the DJI Care Coupon, HOWEVER, this coupon cannot be used in an order that does not contain a consumer product, it also cannot be applied to previously purchased DJI products.
"DJI Care coupons can only be used when purchasing DJI Care Refresh and your NEXT consumer product* in the same order."
So your understanding is wrong. You may choose to give up purchasing the DJI Select if you won't purchase the next consumer product in a short time. My advice, hope this helps.
