DJI Mini 2 Flight Time Test under Real Conditions
5044 27 2020-11-23
Henrik Olsen
Flight distance : 2042385 ft
Denmark
DJI Mini 2 Flight Time Test showing you the real deal when recording footage and photography. This is not a hover test, but power consumption under real use, and you will be able to download some of the samples if you like (link in description).
2020-11-23
jonny007
Same as Mini1 including the f******g beeeeeeeeeeeeeeeeeeeeeeeeeeeep from 20%.
2020-11-23
A J
Flight distance : 13864580 ft
Good honest review - use Sport mode, fly around in full pitch all the time recording 4K, fly in heavy winds and keep taking the drone up and down to and from 400' and you can knock minutes off that time. I am experiencing around 20-22 minutes in real time landing on 20% too without pushing it too much. With three batteries thats over an hour in the air and still good enough for me in one trip without touching a charger but far short of 31 minutes per flgiht - though to be expected - we don't fly in labs I also noticed the low battery warning bleep is much louder on the Mini 2 than the Mavic Air 2
2020-11-23
Monkey007
Flight distance : 73775046 ft
A J Posted at 11-23 12:15
Only done half a dozen flights but also found 20-22 minutes to be quite realistic, without having to worry about a potential forced landing at all
2020-11-23
DJI Stephen
Hello there Henrik Olsen. Thank you for reaching out and posting this video you have created for the DJI Mini 2. Again, thank you for your support and keep on flying.
2020-11-23
Alevpi
Flight distance : 43560 ft
Russia
Everyone has their own real conditions, where the wind is stronger, someone in principle does not use special shooting modes, and someone bought a drone just for them, someone shoots in FHD, and someone needs 4K and everyone will have different flight times.
2020-11-23
A J
Monkey007 Posted at 11-23 13:56
Yeah, if I fly around in cine mode in windless conditions recording in 1080p and force land on 0% I’m sure I’ll get nearer half an hour but I’d rather 20 minutes flying how I need to
2020-11-23
Montfrooij
Flight distance : 2560453 ft
Can you change the percentage to something else than 20% before it starts beeping?
2020-11-24
DAFlys
I thought hovering used more power than flying at 16mph which I believe was the speed they tested this at.
2020-11-24
Henrik Olsen
Denmark
Montfrooij Posted at 11-24 01:00
no not with the current version
2020-11-24
Henrik Olsen
Denmark
DAFlys Posted at 11-24 01:44
Hover will shorten the flight time I'm pretty sure..
2020-11-24
DAFlys
Henrik Olsen Posted at 11-24 01:50
Yeah, that's what I thought.
2020-11-24
Montfrooij
Henrik Olsen Posted at 11-24 01:49
That is too bad.
20% is still a long time if you fly in line of sight!
2020-11-24
MavicMats
Sweden
Interresting to see !
2020-11-24
DowntownRDB
Flight distance : 1722 ft
Great review.  25 mins is acceptable.
2020-11-24
Suren
Flight distance : 13425892 ft
New Zealand
Very nice video
2020-11-24
Scarves UP
Flight distance : 372992 ft
I wish. This also gets you agitated and you might make a bad decision. Bad feature.
2020-11-24
Huginn Keningar
Flight distance : 49635259 ft
According to my last flights the time I spend in the air (taking  photos/videos at 1 or 2 Km distance) is about 18 minutes and land with  40-30% battery. The slower you fly the less battery you drain. I fly to the working area at normal speed (thus I have more time to work), work in cinema mode  (photos/videos), return home in sport mode and land in cinema mode.
NEVER push the batteries to the limit or you'll end up losing the drone. You  need that 40-30% extra battery to confront any problem that may occur  during the flight, just land at 40-30%, put a new battery and take off  again while the other batteries charge. Also, draining the batteries to low voltages is bad for them and last less cycles.
I always return before  the green part of the circle empties, if you wait for the orange to  return, and face a front wind maybe your drone don't return home.
Also  take in consideration that the return to home function flies at low  speed and uses more battery and time that manually return on  sports mode, so it NEEDS that 30-40% battery life to arrive. You don't want to lose signal  or accidentally break the controller and the drone not being able to return on the  automatic return home safety mode.
PS: You can push the batteries  a little only if you are flying at 100 meters or so you have your drone in VLOS, but when flying at 1Km, 1.5Km or 2Km (my  usual flights these days) just start the comeback a little before the  green bar empties.
2020-11-24
Montfrooij
Scarves UP Posted at 11-24 10:34
You can on the MP, so I set it to 7% or something like that.
Flying with this beep is horrible.
Just like something is about to explode.
2020-11-24
Monkey007
A J Posted at 11-23 23:58
Absolutely, 24 mins is about the maximum, on a calm day, no Sport mode, with the critical alarm beeping crazy!!! Photo quality is nothing to write home about; but its flying time matches the Mavic 2's; while its radio range beats the Mavic 2's hands down. Don't know if what DJI says on its website that the Mini2 is on FCC here in Australia..., is making the difference???
2020-11-24
AAM Photography
Montfrooij Posted at 11-24 13:26
Very annoying. Cant say that enough.
2020-11-24
A J
Monkey007 Posted at 11-24 15:04
[view_image][view_image][view_image][view_image][view_image][view_image]
Lovely shots mate
2020-11-24
Montfrooij
Nice shots!
2020-11-24
Montfrooij
AAM Photography Posted at 11-24 15:25
Yes it is.
They must have figured out a lot of error happen in the last 20%
2020-11-24
AAM Photography
Montfrooij Posted at 11-24 23:54
Yes it is.
2020-11-25
Montfrooij
Hope this will be added in the future!
2020-11-25
AAM Photography
Montfrooij Posted at 11-25 06:01
Me too!
2020-11-25
Montfrooij
Wait and see if DJI is reading this!
2020-11-25
