fansf2a747a4
Flight distance : 412802 ft
Sorry if this is a dumb question, but I couldn't find a cable that works. In the Fly More combo, there is a "Battery to Power Bank Adapter", which has a USB (not Type-C) connection. Most powerbanks, including mine, use the same USB connection to charge other devices (and either micro-USB or Type-C) connector to charge the powerbank itself. The problem is that the regular USB port is typically used by "host" device, with the other end of the cable being either micro-USB, Type-C, Apple, etc.). I haven't seen a charging cable that's regular USB on both ends, which seems like the type of cable I would need (effectivelly a host-to-host type cable). Can someone explain how I could use the bank with a more readily-available cable? Thanks
