DJI Mini 2 flight time test with Mavic Mini battery is one of the most requested tests on the channel. How does it handle, does it affect the DJI Mini 2 max speed, flight time, and other factors. I have tested this under real conditions in a mix of recording video and taking photos
Thanks for the test. I did not buy the Mini 2 Fly More package because I already have two Mini 1 batteries. But watch out for horse poop in the motors ;-)
Hello there Henrik Olsen. Thank you for reaching out and for posting this video you have created for the DJI Mini 2. Great work and thank you for your support. .
I think I’ll be buying a couple Mimi 1 batteries as backup. They are cheaper just to have as backup’s
Dose anyone know if the Mini 1 barratries will fit in mini 2 charge bank.
Doug
Donut Michigan Posted at 3-7 10:14
Doug
Even if it does, I wouldn't be using the Mini 2 charge bank to charge the Mini 1 batteries. Since Mini 1 batteries are Li-Ion and the Mini 2 are LiPo, also both have different specs (Mini 1 has lower voltage and max current).
AussieDronePilot Posted at 3-8 04:37
