I have bought the P3. And I seem to experience the interference like in the old P2 with the gopro. I think this is not normal.
Maybe anyone of you know this happens. I was expecting this would be resolved with the P3. If this will keep poping up I wll be forced to seel it or return it to the seller since no videographer doesn not want a shoot that is ruined by this interference.
This is the issue I am talking about. It happened several times now. And I am doubting this P3 drone.
https://www.youtube.com/watch?v=llwosKcl-18
Problem 2:
When the P3 is in hovering by itself 5/10 times the P3 lands insteed of hovering in mid air like it supposte to. Thats why the sensors under the P3 am I right. Hopefuly this is just a firmware bug beacuse DJI can not afford mistakes like these beacuse these were the main advantages od the P3.
Do you mean the slight flicker on the building? Looks more like a camera setting than interference of some sort. Maybe someone else with more camera experience will jump in.
I think kainart is suggested not that it's the props - it's "prop shadow." It's the same effect you get in a room with a ceiling fan that has the lights on top of the fan. Every time the fan blade comes by the light source, you get that rapid shadow, sort of a strobe effect.
