BrianM
mag241 Posted at 12-22 23:49
Hello!
We have similar problem with setting up DJI P4 RTK work with Trimble GNSS reciever (R10 or R10-2). According to the workflow, provided in the last "DJI + Trimble better together" webinar, everything should be quite straightforward - you just set up Ntrip caster via Wi-Fi on GNSS base station reciever an connect remote controller via Wi-Fi to it. However, we can't even connect our DJI P4 RTK and Trimble R10 to remote controller simultaneously. Moreover, when single RC is connected to R10 - there are no corrections throughout "Custom network" RTK option
You need to be connected to the Trimble WiFi through the same controller you are using to fly the drone. To connect to your Trimble unit you have to enter the WebUI first and enable certain settings. Of course, update your reference station to the known point you are occupying or use the here function for post processing at a later time. Update the I/O configuration to enabled at the top check box, select your proper RTCM function, we have been successful in using RCTM3.2 in Florida, US. Set your mountpoint to whatever you would like, and at the bottom there is an "enable" function as well, and that one must be checked as well to broadcast the same as the top selections. Click OK.
When you open the DJI app, which only works with DJI Pilot on and android if you are using the SDK , navigate to the RTK setting. Your server is the Trimble IP address , should be the defualt 192.168.142.1, your port should be the port shown in the WebUI, the username and password is as you set it, and the mountpoint should match exactly as you set it in the WebUI. Once you set those params, and hit save you should be able to watch your Standard Deviations drop to 0.01 |
