Hello there sakis rouvas. I am sorry to know that you are having this issue with your DJI Drone. Can you please try to re-insert the USB cable of the Remote Controller; then remove USB cable of the aircraft and SD card; finally restart the aircraft. After this process if the issue will still persist then it appears that this issue needs to be diagnosed by our team. You can contact our DJI support team to start up a repair case for the said drone at https://www.dji.com/support?site=brandsite&from=nav . Thank for your support.
Lucas775 Posted at 12-6 18:07
Turn on the RC and the craft without cable and a phone/tablet connected to it and see if that works. start the motor with the down/in with the sticks.
Thanks ...but thats not helping ..any other idea i appreciate
DJI Stephen Posted at 12-6 19:42
Its robotics answer ...please get me someone reall human technical to support issues ....
Hello everybody.
I have found the solution to error code 200.
The video signal is transmitted by a cable with 30 very thin wires.
Well ... you need to take apart the drone, the gimball and check that there are no broken wires in the cable.
If the wires are intact, there is most likely a short circuit between the wires that have a thin layer of insulating varnish.
This insulator deteriorates over time and during use, leaving copper wires exposed.
The solution is to spray a thin layer of spray paint between the threads. I leave some photos to better understand the problem.
Hi , i had this issue and I changed the video signal cable and flex cable (because error 200 is an issue with the camera and gimbal) here's the part to fix it https://www.amazon.ca/dp/B07KG2L6YK?psc=1&ref=ppx_yo2ov_dt_b_product_details and https://www.amazon.ca/dp/B095HGHFT8?psc=1&ref=ppx_yo2ov_dt_b_product_details
