vindibona1
Flight distance : 206991 ft
Sean-bumble-bee Posted at 12-3 09:56
Just something to think about, would a strobe on the bottom be damaging for the vision system sensors, it might be too bright when the drone is sitting on it. The M2P/Z has a powerful bottom light built in and that does not switch on until the drone is airborne.
Besides Bashy, a poster here, has said that if he attempts to hand launch his mini 3, with the bottom of the drone in a horizontal plain, the drone will not start motors, see the thread "Mini 3 Pro battery percentage pushing the limits" ......... https://forum.dji.com/forum.php?mod=viewthread&tid=280254&page=1#pid2916363
I don’t think the brightness of a continuous light or a strobe would damage the sensors. I would, however, recommend using one of the several “leg” extenders that are available. I don’t think you want the strobe sitting on the ground with your drone on top of it. If you are indoors, the 250 g threshold doesn’t really matter if it’s important to you at all outside.
The thing is that if there isn’t enough light for the vision sensors to work, I would like to believe that a continuous light on the bottom would really help out. |
