Mark97564
Flight distance : 2067749 ft
Any difference in cell voltages less that .1 is acceptable.. 4.3 volts on 3 of the cells and 4.21 on the 4th cell is acceptable although the battery is getting weak now 4.3 on 3 cells and 4.19 on the 4th is a battery I would be real careful running but I still would considering every other lipo battery I own which is about 30 of them has a fully charged cell voltage of 4.18 to 4.2 volts.. I feel dji is slightly over charging the cells of the p3 battery by .1 of a volt but then again that could just be how they designed it, I'm use to 4.2 volts per cell being the norm on every other lipo battery I've ever seen, although I do have a charger that allows me to change the fully charged cell voltages to 4.5 which I would never do... But considering the fully charged cell voltage normally being 4.2 volts according to any literature you can find on a lipo battery I would still run a p3 battery as long as any of the cell voltages are 4.2 volts or higher.. Any lower I may still run it but would watch it carefully and would keep my p3 close by and not as high as I normally fly in case a cell craps out and drops voltage real fast, I then would have a better chance landing it in 1 piece.. Any cell voltage lower than 4.1 I wouldn't even take the chance on running the battery and I would thing since it's a smart battery that it wouldn't allow a p3 to take off with anything abnormal about its cell voltages.. This is my 2 cents |
