Narrowboat Marina
12Next >
248 49 2020-12-13
Blériot53
Flight distance : 2079941 ft
Panorama canalside of narrowboat moorings.
2020-12-13
Blériot53
2020-12-13
Blériot53
That was the image, compressed courtesy of DJI, and below is the image scaled using G.I.M.P.
2020-12-13
DowntownRDB
Flight distance : 525 ft
Blériot53 Posted at 12-13 04:49
[view_image]
Very impressive pano Blériot.
2020-12-13
Blériot53
DowntownRDB Posted at 12-13 07:35
Thanks RDB. Not sure I like the curved transition imparted, though.
2020-12-13
Montfrooij
Flight distance : 1995141 ft
Nice pano!
2020-12-13
Blériot53
I like the picture but I don't like the curved perspective.
2020-12-13
Montfrooij
Blériot53 Posted at 12-13 09:16
That is typical with a pano that is this wide.
You merge a lot of perspective in a flat image.
There are editors that can help you reduce the effect, but it will be present.
I can give the images a go in autopano giga if you have the separate files.
2020-12-13
Depp
Flight distance : 1140292 ft
Nice. Next one from the air?
2020-12-13
Blériot53
Depp Posted at 12-13 10:36
I may have something in the archives.....
2020-12-13
Blériot53
Montfrooij Posted at 12-13 10:29
DAF made a comment which prompted a thought
There are three shooting modes on the P2:
Tilt Locked
FPV
Follow
Each gives a different result tried indoors doing a 3x3 pano.
I need to get out and try again in each mode to see which gives the least distorted result.
More tests when the weather breaks
2020-12-13
Montfrooij
Blériot53 Posted at 12-13 12:26
Tilt Locked
It might be a bit 'better' (or at least, different) but this is a common thing with panoramic images.
You should 'fold' the image around your head so to speak and look at it as if you are turning your head around.
Some editors let you choose a 'projection' and hence give a bit less rounded result.
Do you have the raw files still?
2020-12-13
Woe
Flight distance : 4129268 ft
Nice
2020-12-13
Blériot53
I do have the four original files - each of which is about 8Mb.
2020-12-13
Blériot53
Montfrooij Posted at 12-13 12:55
They are  4 JPEG files, not RAW.
2020-12-13
Blériot53
Thanks Woe
2020-12-13
Blériot53
Will this do?
2020-12-13
Montfrooij
Blériot53 Posted at 12-13 23:27
That is ok.
Can I try them out?
2020-12-13
Montfrooij
Blériot53 Posted at 12-13 23:26
Nice.
I'd like to try them on autopano and seen how they look
2020-12-13
Blériot53
Montfrooij Posted at 12-13 23:51
That is ok.
Can I try them out?
Yes by all means - I've uploaded them to Google Drive.
2020-12-14
Montfrooij
Blériot53 Posted at 12-14 00:13
(where is your google drive?)
2020-12-14
Montfrooij
Never mind, I was too early!
2020-12-14
Blériot53
Montfrooij Posted at 12-14 00:15
I've used Microsoft ICE to re-do the panorama, and altered the option to Perspective view with auto crop and it seems better
2020-12-14
Blériot53
Blériot53 Posted at 12-14 00:43
[view_image]
But now the large file suffers from over-compression as it passes through the DJI filter
2020-12-14
Montfrooij
[view_image]
Yeah, they can stretch those images quite much.
It will affect the image quality though.
I'm working on the batch now.
2020-12-14
Montfrooij
[view_image]
This is what Autopano thinks it should make of it.
Actually it looks very nice, but you really have to think about it as something that you print out and wrap around your head so you can look left and right and see what your eyes would see in the real world.
If you make that a 'flat' image, it looks distorted (but that is just how it is with panos)
2020-12-14
Montfrooij
[view_image]
And this is how I would render it.
It is the perspective 'little planet' and with the option 'keep horizon straight' on.
As a rule of thumb : everything that runs parallel to the camera will look 'round' when you rotate the camera to make panos.
The effect is less prominent from a distance (so with a drone you sometimes can manipulate the projection enough to make it look 'sort of' straight)
But most of the time panos work 'best (with little distortion) when there are not obvious straight parts in them that run parallel to the camera.
2020-12-14
Montfrooij
Finally, remember most viewers won't know if the canal is curved in reality
2020-12-14
Blériot53
Montfrooij Posted at 12-14 00:45
I've scaled it down now
2020-12-14
Blériot53
Montfrooij Posted at 12-14 00:50
Well it does actually curve at that point, but not as much as it appears
2020-12-14
Montfrooij
I think with this type of location a panorama is nice, but it will curve a lot.
Still it is a nice way to show what a place looks like.
I personally would not use a pano here, but focus on both sides (first and last image of the batch) where you seen the canal disappear.
Or try and capture it with a drone (from further away)
2020-12-14
Montfrooij
Blériot53 Posted at 12-14 00:56
I have had a lot of tries with panos from the drone and it is always 'hard' with straight lines that run parallel to the camera.
2020-12-14
Blériot53
Montfrooij Posted at 12-14 01:11
Check out #17 above, which I posted at Depp's request
2020-12-14
DAFlys
Flight distance : 1276493 ft
This one needs a little spot healing bottom centre.
2020-12-14
Blériot53
DAFlys Posted at 12-14 01:13
You noticed the grass apparently growing in the path
2020-12-14
Montfrooij
Blériot53 Posted at 12-14 01:13
I like that one!
2020-12-14
DAFlys
Blériot53 Posted at 12-14 01:15
Yes indeed.  Easily fixed I would think.
2020-12-14
Blériot53
DAFlys Posted at 12-14 01:20
I think I've fiddled about with that one quite enough
2020-12-14
DAFlys
Blériot53 Posted at 12-14 01:32
Hows this?
You can play spot the difference.
2020-12-14
Blériot53
You've cut the grass
2020-12-14
12Next >
