DJI Pocket 2 and Samsung Galaxy Note 10 up side down
3894 17 2020-12-15
ArmandoN
Flight distance : 21332 ft
Mexico
i just got my new DJI Osmo Pocket 2, and i use a Galaxy Note 10 Plus, but the first time that i connect the Pocket with my mobile it was funny that i had to contect it the other way arround, it was ok for the set up, but now i cant work with the mobile flip  any one has the same problem?
this is the correct way but, no working....
2020-12-15
DJI Susan
Hi there, just to clarify, the camera of DJI Pocket 2 is now in Selfie mode, to quit selfie mode, please press the function to switch the camera facing the opposite way.
The mobile device's screen and Pocket 2 screen should be facing in the same direction. Please turn the phone the other way around and see if it gets back to normal. You can also try to unlock the screen lock. See if this helps.
2020-12-15
ArmandoN
Mexico
DJI Susan Posted at 12-15 20:01
it wont work, is not in selfie mode,  i al ready call samsung help and they say that the phone is correct!
i don´t know if is compatible...
the only way that the phone recognize the camara is the if i connect the other way arround like in the picture i show
2020-12-22
DJI Susan
ArmandoN Posted at 12-22 09:57
Thank you for getting back, ArmandoN, could you please tell me the DJI Mimo app, the Android system version of your mobile device, and a video of the issue (connect the mobile device in both directions)? I will also forward the case to our engineers for their attention.
2020-12-23
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
hi ArmandoN.
plz make the phone screen the same side with pocket2 screen.
Then everything will be fine.
plz refer to the pic:
2020-12-23
ArmandoN
Mexico
DJI Susan Posted at 12-23 02:51
here is a link showing the issue.
https://youtu.be/3lH856aNttI
2020-12-23
ArmandoN
Mexico
DJI-ytao Posted at 12-23 05:20
hi ArmandoN.
wont work that way, but if i connect the other way arround works...
2020-12-23
DJI-ytao
DJI R&D Squad
ArmandoN Posted at 12-23 10:04
the current way is the "other way arround" .
The layout of DJI Mimo just has two orientations: landscape and portrait.
It is recommend to use by connecting phone "other way arround" because the record/function buttons on pocket2 can also be used when shooting with phone.
And gimbal can to turn forward and backward by itself.
2020-12-23
DJI Susan
ArmandoN Posted at 12-23 10:02
Thank you for getting back, it seems from the video that you had tried 2 Pockets but the issue is the same.
Could you please tell me the Android system version as well?
Besides, if there is a chance, please try another mobile device that has a USB-C connection port to double confirm that if the issue relates to the adapter.
2020-12-25
Michael_s_official
Flight distance : 60948 ft
Also the same problem like ArmandoN!!!
I use the Samsung Note 20 ultra 5G with Android 11 and have to change the direktion of Pocket 2. Otherwise it will not connect.
Guess that it is a Samsung NOTE problem because it works with my girlfriends Samsung Galaxy 20FE without any problems.
I cant usw it :-(
2021-1-26
ArmandoN
Mexico
DJI Susan Posted at 2020-12-25 04:16
I tried with a Samsung Galaxy S10 and work correct, i also tried with a Iphone and works
my phone  is a  Samsung Galaxy Note 10 SM-N975F  Android Version 10
2021-2-14
DJI Susan
ArmandoN Posted at 2-14 09:38
Thank you for your confirmation. I had noted the issue and let our engineers notice it.
2021-2-21
Flakmunky
I have a Note 10+ and downloaded Mimo 1.5.12 from DJI's website as the version on the Play store was older (1.5.8 I think, or maybe even 1.5.4) and I haven't experienced this issue.
2021-3-5
djiuser_GVYtch4dExSY
India
I have same problem. I m using note 10 plus but I have been told by dji representative that it is not compatible with samsung galaxy note 10 plus.  DJi technical team should resolve this problem at the earliest.
2021-6-12
HGDC84
Finland
djiuser_GVYtch4dExSY Posted at 6-12 09:50
Some phones that DJI doesn't state to be compatible may still work with the Pocket 2 if other certain requirements are met. If you have problems with this model, see the troubleshooting tips at https://forum.dji.com/forum.php?mod=viewthread&tid=235190 (the thread that lists tested compatible models not mentioned by DJI and non-compatible models) and see if some of them could solve your problem.
Hopefully you will get your problem solved!
2021-6-13
India
Can I get latest list of compatible mobile phone model for dji pocket 2
2021-7-11
DJI Thor
Flight distance : 13602 ft
djiuser_GVYtch4dExSY Posted at 7-11 19:31
Hi there, may we know which mobile are you using? You may check the compatible list in the blowing link:https://www.dji.com/downloads/djiapp/dji-mimo. Thanks and best regards.
2021-7-11
HGDC84
Finland
The link on my post - right before yours - includes a list of phones that, while not officially sanctioned by DJI, have been tested with the Pocket 2 and have proven to work, either by my own tests or by testimonials of other forum members. If you can't get access to the official list's phones (see DJI Thor's post above this one), you could try one of the models on my list.
Also, If you have no access to a compatible phone but have a tablet (or would prefer one for larger screen etc.), you could check out the list of tested tablets at https://forum.dji.com/forum.php?mod=viewthread&tid=237518 .
Both of these lists are updated from time to time, when I have a chance to test compatible models or hear from other people's test results.
Hopefully you will find a model that suits you best.
2021-7-12
