pimmow
Ssaumlsch Posted at 12-16 05:47
12V is not possible I think but first party DJI accessories like the focus motor are supplied with 8V or 8,5V. So maybe we can at least hope for that, not enough for my BM Pocket but I can power a Teradek or Tilta Nano motor with that.
For now the newest update broke stable 5V output out of the top USB C port for me
ok so i did start soldering;
Since i like using the ronin rs2 with the side bars; and extension handle; i bought one. the extension handle is connected through a small RSA breakout box that connects to the side of the rs2. it has one port, that connects to a cable to the tethered handle. all proprietry cables. i unscrewed the plugs and measured the voltage. its indeed 8,5 to 9V that feeds the tethered handle. i have a field monitor i want to connect, without adding batteries. it works from 7v; but uses 18w since its a 2200 nit bright monitor. i connected the monitor to the proprietry cable in between the rsa port and the external handle; bij just peeling off a small piece of the rubber mantle of the cable; then doing the same from the red and black wires that are inside; and without cutting them i just soldered the extra cables onto that, and connected those to the monitor. And voila. it works. Because the monitor is so bright and it uses a lot of power; i could only get about an hour of power for the combination. with the ronin m i got a bit more, but then i didnt put the brightness of the monitor at 50%, so it deliveres more power. i noticed the ronin rs2 battery only gives you 1950 mah of power which is actually very little. my small canon bp30 battery that is 14,4 V gives me 3000 mah, and is lighter... so i'm thinking of putting an adapter in stead of the original battery, and connect the canon battery.
ok hope that helps you guys!
Pim
