IMU NOT CALIBRATING ERROR 30055-30056-30084
1029 2 2020-12-25
Vpug
Flight distance : 3127 ft
Hi
I have 2 mavic mini one I had damaged broken leg/motor and gimbal before buying any parts thought I would
swap the parts of my other to check that was all the problems, on swapping parts gimbal was pointing to one side
and coming up with fault codes but camera working.
I then swapped parts back now cant fly my other Mini I am getting IMU NOT CALIBRATING ERROR 30055-30056-30084
I have tried to calibrate 20 or more but it only gets to a low % on first stage and stops but I can see in the background the speed and altitude go
rapidly into - figures.
I have replaced the IMU and ribbon cables but still the same, Has anyone had this problem and overcome it.
Thanks for looking
2020-12-25
DAFlys
Hi! You might be better off posting your question in the 'products' section of this forum.  That is way more active.
2020-12-26
umair air2s
Hi was anyone able to get these error fixed I am in a similar boat and tried replacing GPS module, GPS flex cable and IMU module but the errors (30055, 30056) are not going away. Please share your experiences it might help me thanks
2022-9-22
