fans5c1acfb3
Flight distance : 898189 ft
Finland
DJI Stephen Posted at 2020-12-29 02:02
Hello there. Thank you for reaching out and for choosing DJI. Upon checking the said mobile device ( OnePlus 8T ) that your are trying to use on the DJI Fly application. I am sorry to say that the said mobile device is not recommended for the said application. We would suggest using a recommended mobile device for the DJI Mavic MIni 2 and with the DJI Fly application for compatibility and reliability purposes. There is a possibility that the OnePlus 8T will be able to work on the DJI Mini 2 and with the DJI Fly application. But however, since it's not yet optimized with the said drone and with the said application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Fly application while using it on the DJI Mini 2. For reference I will post a link where in you can check the recommended mobile devices for the DJI Mini 2 ( https://www.dji.com/mini-2/downloads ). Thank you for your understanding and support.
well, yes, since the oneplus series 8; 8T; 8Pro, are not compatible with the DJI Fly app, why don't they make the entire mavic series including the mini, Air 2, Air 2S, and mavic 3, workable with DJI GO 4, which is compatible with most mobiles. Because once you spend a fortune on a drone, you also have to spend money on another phone, having an app like DJI GO 4 that is compatible with most phones. I think it's not fair. or you guys from DJI think that money falls from the sky. |
