New DJI Smart Controller Firmware Released (12/28/2020)
123Next >
9873 85 2020-12-29
OlliM1971
Flight distance : 309199 ft
Hi guys, received an OTA update of the DJI GO 4 App for the SC this morning. It’s on version 4.3.38 now...
2021-1-3
bjr981s
Flight distance : 139698 ft
OlliM1971 Posted at 1-3 02:29
Excellent. Thanks for the post.
2021-1-3
djiuser_L2NZHKGW0FWF
Flight distance : 122395 ft
thanks ... just updated DJI GO 4 .... I always had problems with the smart controller and DJI GO 4 ... the app was constantly disconnecting ...... hopefully now the problem is solved !!!
2021-1-3
AntDX316
Flight distance : 3394731 ft
How do you get the update??
2021-1-3
AntDX316 Posted at 1-3 05:58
in DJI GO 4 app ..... Me ..... settings top right ..... Check for Update
2021-1-3
Dji Go 4 app on Smart Controller
2021-1-3
AntDX316
djiuser_L2NZHKGW0FWF Posted at 1-3 06:20
I did, it's still .336
2021-1-3
unstable flight
Sweden
AntDX316 Posted at 1-3 08:29
A Smart Controller with a firmware version of v01.00.04.75 or earlier must be updated using DJI Assistant 2.
2021-1-3
in fact I first updated the smart controller with DJI Assistant 2 with usb cable and pc .... and after on the smart controller I updated DJI GO 4....
2021-1-3
AntDX316
unstable flight Posted at 1-3 08:36
.336 is latest or .338?
2021-1-3
Dji Go 4 version 4.3.38.....Firmware 01.00.0860
2021-1-3
DroneJunkieQc
Flight distance : 1015679 ft
KlooGee Posted at 2020-12-29 05:31
Mini is never going to happen, but disappointed if they don’t add Mini 2.
I am also desperately waiting for Mini 2 support on SC.
2021-1-3
KlooGee
Flight distance : 16783757 ft
DroneJunkieQc Posted at 1-3 19:16
Yes, I hate flying with my phone or having to mess with a tablet holder and cable for an iPad.  SC is just so easy.  Turn it on and fly and you can see easily with that bright screen!
2021-1-3
Monkey007
Flight distance : 73775046 ft
KlooGee Posted at 1-3 19:36
Can't agree more, the Smart Controller is so much easier to deploy. It just feels more comfortable to hold with my hands. Though I've always wished the stick tension are adjustable like they are on a conventional RC helicopter transmitter. But they're still better than the standard DJI remotes.
2021-1-3
Tha Wiz
Flight distance : 317008 ft
we need that mini 2 !!!
2021-1-3
michimue88
Flight distance : 841260 ft
Switzerland
10min Download. works fine for me
2021-1-4
Monkey007
Updated to 4.3.38, it all went smoothly and quickly. Not sure if the app crashing issues are solved; but VERY DISAPPOINTINGLY the histogram still goes back to a default spot next to the map box, obscuring the distance display every time it starts up. Come on DJI, this is simply UNACCEPTABLE!
2021-1-4
ET214
Flight distance : 634505 ft
FloridaNext Posted at 2020-12-29 09:47
-> Improves overall stability.
So? What stability issues were in the previous version?
Sometimes  the Go4 app on  my SC would crash.
I haven’t experienced any issues  with the GOFly App, but then again, I sent the SC in to DJI for repair
just as they released the compatibility with the MA 2 and the SC.
2021-1-5
DH_Pilot
Flight distance : 3301621 ft
Slovakia
After update to this FW my SC was totaly unresponsive the other day - needed to reset it with holding power button + c button under, never happened before. I doubt about stability of this firmware
2021-1-6
ET214 Posted at 1-5 12:44
I haven’t experienced any issues  with the GOFly App, but then again I sent the SC in to DJI for repair
just as they released the compare with the MA 2 and the SC. The
I still have not had the opportunity to test the smart controller with new DJI GO 4 version and new firmware .... there are still crash problems with DJI GO 4 .... thanks ...
2021-1-6
JohnDG
Flight distance : 1097270 ft
Malaysia
djiuser_L2NZHKGW0FWF Posted at 1-6 03:32
try a factory reset and reinstall the latest firmware using the DJI Assistent and a pc.
2021-1-6
daro1265
Flight distance : 16267723 ft
Switzerland
djiuser_L2NZHKGW0FWF Gepostet um 1-6 03:32
Ich hatte immer noch keine Gelegenheit, den Smart Controller mit der neuen DJI GO 4-Version und der neuen Firmware zu testen. Es gibt immer noch Absturzprobleme mit DJI GO 4. Danke. .
Bin Gestern 2 Akkus mit der neuen Go4 App (v 4.3.38) geflogen und keine Probleme festgestellt
2021-1-6
CONGRATULATIONS DJI !!!
2021-1-6
TrevorSK
Flight distance : 1547713 ft
Is there any good reason I should do this update.. I’m afraid all it will do is be a bunch of fooling around and then I’ll have to set up all my settings again
2021-1-8
jmb63
Flight distance : 7009439 ft
I had weird crashing of the GO4 App on the SC after that previous update (v01.00.0820) I went back to the previous version... NOW this version (v01.00.0860 ) seems to have corrected those crashes so far...(fingers crossed)
2021-1-8
jmb63 Posted at 1-8 04:36
thank you very much .... I have had many crashes .... to be sure I also used the original controller (in slave) together with the smart controller .... DJI GO 4 on smart controller every time it crashed !!!!!
2021-1-8
JussipaitaFIN
Finland
This is my first issue with the Smart Controller. It won't update. It gets stuck in 15% and won't proceed forward. I have tried multiple times with wifi and DJI Assistant 2 for Mavic to update the controller and EVERYTIME it gets stuck to this 15%. I used the program with Mac pro and Macbook pro. Ive made the hard reset to factory settings and nothing works. I can't connect to drone because the controller needs to update it first. Any advice please before I throw this ... on the wall.
Ive seen this info so many times...
2021-1-8
I did the update with Windows .... try to reset the factory settings on the smart controller and update only via wi-fi...
2021-1-8
jmb63
JussipaitaFIN Posted at 1-8 22:14
Review all the info/posts regarding the upgrade procedures from the last update (Sept. I believe) ....There is plenty of info and links in that thread.
Quite a few things to check and too much to repeat here but if you review that thread in this DJI forum, I predict you will work it out...
Lots of useful posts/videos on YouTube as well.
2021-1-9
KREMi
Poland
give us MINI2!
2021-1-9
Forestjim
Flight distance : 6606519 ft
Give us Mini 2 !!!!!!!!
2021-1-10
FlyRacer
Flight distance : 281880 ft
Lost my whole videos on the sc by updating this firmware,... not so happy.. why is it every single time so complicated to do that firmware update, cant beliebe it
2021-1-10
KlooGee
Mini 2 please!
2021-1-10
Monkey007
Yes DJI, give us Mini2, it's a promise, NOT a favor!!!
2021-1-10
AntDX316
The new update fixed the stuttering.  The quality is back again.
2021-1-11
ro_flyer
Flight distance : 7557283 ft
Brazil
2021-1-12
Repaid1
New update out V01.00.0880
Release notes:
Fixes crashing issues and improves App stability
Add Local Data Mode.
Mini 2 nowhere in sight, nor actually promised either when released unlike the MA2.
2021-1-12
djiuser_V7z7edxDy4qp
Flight distance : 2062339 ft
CMNDR Posted at 2020-12-31 17:53
Happy to report that the new firmware update for the DJI Smart Controller fixes the issues with the Mavic Air 2.    The compass on the map now orients the drone correctly in relationship with my location.   The stuttering and glitchy app navigation is now smooth and buttery.    The range of the stock MA2 controller is still better when comparing their range, but they are very close.
Thank you DJI forum people for hearing my complaints!
Hi CMNDR, updated the SC firmware, but the compass orientation of the SC and the map is still 180degree off when flying Mavic Air 2....
Did I do anything wrong?Many thanks
2021-1-13
AntDX316
ToscanaDrone Posted at 2020-12-29 05:21
No DJI Mini compatibility?
Why would you use the Mini over the Air 2 unless you are indoors?
2021-1-15
DJI GO 4 CRASH !!!!  today I was able to test my M2Zoom with smart controller updated to the latest firmware and the latest version of the Dji go 4 app .... the problems ARE NOT SOLVED .... in flight the app crash and returns to the home.  ... GO FLY ... THANKS DJI !!!!  KEEP IT UP
2021-1-19
123Next >
