JJB*
Flight distance : 12225059 ft
Hiya,
Just tested my MA2 in the latest firmware and use of the Android FlyApp 1.2.1.
Why 1.2.1? because version 1.2.2 cannot be converted to a usefull CSV file.
The optimzed RTH does work on 1.2.1. [ between 50 -5 meter direct to home ]
Remarks:
- flying lower than 5 meter craft will climb to 5 meter before flying back to home
- when an obstacle is in the way of this direct line towards home ; craft will cancel the RTH, message on the screen "Obstacle ahead. Ensure surrounding envirionment is safe and return home manually". Thus in this RTH craft will not try to climb using the OA.
- Notice that you can bring craft lower/higher using stick, forward stick increases speed but aft stick cancels RTH. Roll and Yaw doesn`t work at all, while before it was possible to yaw craft. (making full circle possible while craft stayed at 1 line to home (btw useless but nice...))
cheers
JJB
