info.marcelvoss
Flight distance : 1795 ft
Hi there,
Yesterday I've tested my Phantom 3 indoors in a large open hall, and I didnt' think of changing the mode switch on the remote.
The GPS signal was not available so the P3 was in the P-OPTI mode first and also switched to P-ATTi (probably at higher altitudes) when I check the flight records.
It was possible to fly but it took a lot more steering skills, I noticed the Phantom 3 was not 100% stable and started to drift a bit with both sticks untouched compared to flying outside.
Is this the best way to fliy indoors, or should I change the position on the remote to another mode to increase stability?
If anybody has experience with flying indoors, can you confirm if the way it behaves remains about the same during a flight?
Or can it do unexpected things other then a bit of drifting, like dropping a lot causing it to crash?
My goal is to use it to chase a bowling ball, like in 'The Big Lebowski' , but I dont want it to crash into the wall or something.
