New DJI Pocket 2 Firmware Released (01/05/2021)
1234Next >
22978 140 1-5 07:54
arthurbikemad
Flight distance : 49954 ft
John Walker Posted at 1-9 05:53
"Also I read here on this thread the shut down direction of the gymbol, mine seems to shut down with the head in a position that leaves the power button exposed, not that it matters when in the case as it seems you can put it in the case any way round... anyways... tiz what it is...."
Sounds like you are putting yours in the case upside down.    The 'ridged' side of the gimbal should face out.  The flat side of the gimbal head should be at the bottom and fit snug on the round yellow foam protector (Unless you took that out thinking it was only packing perhaps.
Your right, its just my logic that the camera would be fully or better protected the other way round, also now you can power up the camera with the second button twice now I have removed the camera from my bag to find its already powered up and the gimbal locked, I'm guessing that the case presses the button on the sidewall (front power button) when placing back in the case or when packed somehow.
1-10 07:44
trevm
As someone else mentioned earlier - I have the headphone monitoring with the wireless mic working when recording,  but the volume is almost inaudible, even when the audio meter is showing a good level.  During playback of recorded clips the volume is fine.  Has anyone worked out a fix for this yet?
1-10 08:31
trevm
fansfe82067d Posted at 1-6 06:23
The level of the new monitoring feature seems very low and I can't spot a way of adjusting it.  Not really useful as it is.  In playback you can swipe up or down to change volume, but even if I set max volume in the playback function, it doesn't affect monitoring volume, which seems set at about 10 out of 100 (compared to playback volume).
Same for me.  Have you found a fix yet?
1-10 10:21
fansfe82067d
OSR67 Posted at 1-10 04:46
It would be nice to be able to set the Gimbal to Lock Mode also in the Mimo app.
When using the DJI to GoPro mount accessory, you cannot use the Mini Control Stick. When attaching the Pocket 2 to a car for example, using the lock mode would be useful. Using the Mimo App would be very helpful.
If you have lock mode on in a car with the camera pointing out the windscreen, if you turn left the camera will now be pointing out of the right side window, which is probably not useful.
1-10 12:53
GiuseppeC
Hello,
sadly my DJI mimo do not see any upgrade to be downloaded.
There is a way to manually force it?
1-11 03:52
Yayoastur
GiuseppeC Posted at 1-11 03:52
Hello,
my dji mimo don't update neither
1-11 07:21
Coris
Romania
I have to say that it is quite strange that in whole this thread  (4300 viewers right now), where mostly it are criticised many aspects regarding the new Pocket 2 firmware, no one from DJI team , nor any "moderator" have commented or answered to the numerous issues reported or noticed here...
HELLO DJI! Where are you now?
1-11 09:30
Aavalaakso
Finland
Coris Posted at 1-11 09:30
True. Never seen so much views and posts in Pockets firmware notes in two years without any official comment..
They did not comment anything about the case problems either. https://forum.dji.com/forum.php?mod=viewthread&tid=231363
It also feels odd that you can start the Pocket using two different buttons but can turn it off using only one button. Make menu where to select where camera is positioning when turn on!?!
Active Track is still a LOT better in Pocket 1. Same with face.. and other things mentioned in these posts.
1-11 23:39
fansfe82067d
Aavalaakso Posted at 1-11 23:39
There is no button 'spare' for turning off the device.  A long press on the function button activates momentary gimbal lock.  You can bet that if they changed that existing assignment, they would upset the users who like it the way it is.
1-12 00:50
John Walker
Hello,
Delete and re-upload
1-12 05:54
fansb5a035e5
Hi, I can't find Trimmed download function in Playback. Where is it? Thanks
1-12 13:40
fansb5a035e5
1-12 13:42
kamain
South Korea
Blellow Posted at 1-6 15:32
Can we disable .LRF files?
I need an option to disable the creation of .LRF files.
I don't want those files, but they uselessly take up space on my SD card.
1-12 14:27
Gollan
With the new firmware, my Pocket 2 now recognizes that an ND filter is installed (with a message on the screen) and correctly powers down with the lens facing out. I appreciate this fix.
1-12 20:08
Coris
Austria
Pocket 2 it recognize now even an third part ND filter, and it power off with camera accordingly positioned. Nice indeed!
1-13 03:36
fans44ce158f
Turkey
Hello DJI POCKET 2 I have installed FIRMWARE UPDATE V01.02.00.50 but HDR video and Story Mode does not appear on my device. Please help me. I did a reset. I formatted the card, it didn't work again
1-13 12:25
fans44ce158f
Turkey
1-13 13:10
djiuser_oZpNEnBdTxOA
Thailand
Mimo continuously crashed on Samsung S20 ultra. I can't use it without a crash. Also, when the pocket is connected via USB to the phone, and I use the glamour effect, the photo is black... See attachment. Anyone can help?
1-14 20:47
Thailand
djiuser_oZpNEnBdTxOA Posted at 1-14 20:47
1-14 20:48
Thailand
1-14 20:48
Thailand
1-14 20:53
PhilBro
Hallo, unfortunately my Pocket 2 turns always into selfie mode, when I start the device. Can I set up sth. to avoid that and have the center FPV camera position as I had it before the update....?!
1-15 00:46
John Walker
PhilBro Posted at 1-15 00:46
See all the previous answers to the same question,
1-15 02:34
Indio
Flight distance : 104259 ft
Austria
fans44ce158f Posted at 1-13 13:10
[view_image]
[view_image]
have you switched to the pro mod?
1-15 03:22
fans44ce158f
Turkey
Indio Posted at 1-15 03:22
yes i passed but still not happening
1-15 08:46
Dualped
djiuser_3mzRaK35HJlM Posted at 1-6 09:59
Since the update, my pocket starts in selfie mode. Can you change that?
The power button will start in selfie mode but instead of the power button when it's off just press and hold the function button & it starts in normal mode, they did that on purpose.
1-15 10:06
Dualped
John Walker Posted at 1-15 02:34
1-15 10:10
Dualped
The issue that I'm having is with the external lens that came with the combo, the gimbal vibrates :-(
It has always vibrated regardless of firmware, is there a fix for this? Is anyone else having this problem?
Thx
1-15 10:12
Anand Z
Flight distance : 29741 ft
India
This firmware upgrade bricked my DJI wireless mic. It said "upgrade failed" after blinking green and red for some time on my wireless mic. Now my wireless mic is unable to connect to my Pocket 2. I tried several times. Any way to reset the wireless mic or roll back to the earlier version of the firmware??
1-17 00:24
Coris
Austria
I think you should not try to fix yourself a such issue. Not possible also to be fixed, but by only DJI service dept. That device firmware should be flashed/loaded again in a particularly maner. The only alternative for you is to contact DJI for a eventual replacement...I am still wondering why in this whole thread, initiated by the DJI support team, this supposed support team it have no any whatsoever intervention (except the first post), or comments to the so many issues/critics reported here...
1-17 01:42
ivanf197
Flight distance : 555417 ft
Israel
Hi Dji,
Are you know that Active Track is reliable... until record will be enabled? While recording is disabled, the active track works as minimum equal to pocket 1. But when I start recording, active track on pocket 2 starts to behave unreliable, inaccurate, loses target etc. Same as it was in previous firmware.
Opposite to this, active track on pocket 1 - remains accurate at recording. I checked this on two devices (op1 and op2), attached to common base plate.
Is this supposed to be fixed in near fw?
1-17 17:48
PatLam
"Added Trimmed Download (DJI Mimo of v1.5.8 or later required)."
May I ask what is this for ???
1-18 06:17
PatLam
"HDR CROP"  is very disappointing !!!!
1-18 06:19
PatLam
KI story is improved !! Thanks !!
1-18 06:20
djiuser_Q26rL2L3VYGt
Decent update.
Hoping to see a couple of features to make it a social media vlogging machine.
- Background Blur
- Glamour mode 4K 30/60
- Better low light performance
- Direct upload to Instagram Story
- Live Steam on Instagram
The whole purpose of this is to vlog and for social media so it needs to focus on that aspect in my opinion.
Great piece or kit though and look forward to creating.
1-19 03:20
Kotaix 1
Flight distance : 932228 ft
Chile
Hi there. Since I did the firmware update, my Pocket 2 turns on in selfie mode, instead of facing forward as usual. It is very annoying.How can I solve this? Did it happen to someone?
1-19 08:43
John Walker
Kotaix 1 Posted at 1-19 08:43
Use the function button below the screen.  The power button on the side is for starting up in selfie mode.
1-19 09:19
Kotaix 1
Chile
John Walker Posted at 1-19 09:19
It works perfectly (thanks a lot) ... but it's weird, before the update, the button on the side turned the pocket 2 in the forward position ...
1-19 10:42
AHB_Pck
Turkey
[view_image]
[view_image]
video image.      https://drive.google.com/file/d/13aA0mMsvm2ZptmLT_LO6iKA7j_kyTBV1/view?usp=sharing
1-19 11:20
Dualped
This firmware has fixed the audio hissing that I had BUT it has introduced a NEW PROBLEM darn!
1-19 12:10
1234Next >
