Geebax
Arpettaz Posted at 1-8 13:48
In my opinion, the 180 rule (motion blur) you are referring to only really comes into its own with motion/action shots, like with an action camera. Unless you are going to ignore the drone rules, most people won’t be using their Mini 2 for close action shots and so for me motion blur is irrelevant for a drone. I also only use ND filters for photo shoots with a hand held camera, and normally use the highest shutter speed I can for drone video commensurate with the light conditions @ 4k 30 fps. I also don’t understand why anyone would significantly reduce the amount of light getting into the Mini 2 by using an ND filter if your shutter speed is only 1/60
"I also don’t understand why anyone would significantly reduce the amount of light getting into the Mini 2 by using an ND filter if your shutter speed is only 1/60"
Inasmuch as you come from a country where the daylight is dull, you would not have the problem of achieving 1/60th second shutter speed. The use of an ND filter is necessary in countries with very bright sunlight, and unless you use an ND filter, you cannot get the shutter speed down to 1/60 without over-exposing.
