Sean-bumble-bee
Flight distance : 15997 ft
fansb4f50ec1 Posted at 7-19 11:36
I had a minor bump on my mini2, after which one motor would not turn properly. It turned out that one of the tiny magnets in the rotor was no longer glued to it's proper spot. This was very hard to notice as it was quite close, and didn't move around given the strong magnetism. I was able to remove it, and the drone works as if nothing is wrong.
Did you apply the tiniest smear of glue etc. and reinsert the magnet, if not then the motor is out of balance.
The motor diameter is around 18mm so lets say the magnets CoG is 8mm from the axis of rotation, Mavic Mini motors run north of 10,700rpm, I am on the wrong computer to process any DATs. 10,700rpm is from a random csv of one of the DAT's that I have previously processed. I think I have seen RPM in excess of 12,000.
I suspect a mini 2 will not be far behind. Plug 10,700rpm @8mm into the calculator
https://www.calctool.org/rotatio ... n/centrifugal-force
and you get.......well look for your self, switch the "centrifugal acceleration (a)" to g to see how many g (earth gravity) the magnets are feeling.
I would hover the drone and touch the underside of the motor mount/arm and check how much vibration you feel.
