Aerial-Image.co.uk
Flight distance : 1452408 ft
SOLVED - When you switch into PANORAMA mode by default the CAMERA setting goes to NONE which means it stitches and creates a jpg file on the drone ready to use - there are 2 other CAMERA image options to choose from JPG, & RAW this then saves the original full-sized unstitched images on a sep folder called PANORAMA.
Maybe because I updated the firmware it re-set some of the setting I had selected previous - So all OK & good
But MAYBE rename the 'NONE' to say 'AUTO' might be a better option..
So it would be shown as - AUTO - JPG - RAW -
