JJB*
Flight distance : 12225059 ft
Hi,
Interesting, but not sure about the cause.
It happens to all DJI`s when the bottom sensor measures height ** AND at the same time for short moment stick down is applied. This will command the drone to perform an autolanding.
** at 0.5 meters height autolanding can be initiate by down stick for short moment.
Bottom sensor can measure incorrect 'height' due to fog, water on the lens, reflections.
IIf you like upload your flightlog using this > https://www.phantomhelp.com/LogViewer/Upload/
In the log the bottom sensor height values are there, so it can be checked
cheers
JJB
