Christianslw
Flight distance : 227654 ft
Hey,
on wednesday the 6th I've been out flying my Air 2 in a cold and foggy environment.
After 2:30 the drone committed suicide.
So ofc. I instantly did an inquiry as soon as I came home.
Filled in all the details (it's insane that the description is limited to a few hundred words, you should remove that dji), uploaded a video to YouTube and inserted a link to some images showing the moisture indicators still being white when picking up the crippled bird.
What enrages me is that after waiting a few days, I contacted the support today and I basically found out that there has been some non-explainable issues, which resulted in the case to 'not be saved correctly'. When checking the case number it's just stuck in awaiting package even tho I haven't received any label yet.
So the support told me to just open up another inquiry, which I just did now. Flaming around about that wouldn't give me anything I guess, still, extremely annoying. Especially because I would've been waiting until the end of my days if I hadn't contacted the support.
I would like to explain the incident a bit closer tho.
Basically all weather services were displaying ~10km/h wind speeds without any gusts.
There have been no warnings whatsoever and the transmission quality was perf.
Still, the drone struggled to do panorama shots because it wasn't really staying as steady in the air as it used to.
After 2mins the drone started drifting around and steadily lowering it's altitude, heading into a concrete tower.
No reaction to any steering attempts whatsoever.
What bothers me is that in the cached video it is clearly visible that the drone lost balance in the air already, there was no sign of a bird hit or smth similar.
it also shows that it collided with the tower after already falling towards the ground.
Seems like only time will tell me the reason of why it crashed like that.
I can definitely say tho, that what I experienced till now wouldn't lead me into buying from DJI again.
From now on it will probably take weeks until I receive my drone back, I mean it hasn't even left my home due to DJI's system failure.
Also not looking forward on paying the 70€ for a replacement even though the drone just committed suicide without any warning or critical conditions. That's just odd.
There's no way DJI will consider it a warranty case because of the mere fact I flew the drone in fog, even tho vision was always present, there was no moisture in the drone and signal was splendid. It's just annoying, insanely annoying.
Cheers.
