Like me, many are having video problems with Lightbridge , well, today tested several resolutions and many do not work according to the LB manual.FAIL = NO VIDEO. AV
PAL25 OK
NTSC30 OK
HDMI
720p50 OK
720p60 OK
1080i50 OK
1080i60 OK
1080p25 FAIL
1080p30 FAIL
1080p50 FAIL
1080p60 FAIL
TESTED EQUIPMENT:
MARK CANON 5DII OK
POWERPACK TABLET HDMI OK
BLURAY PLAYER OK
AZBOX TWIN OK
SJ4000 OK
GOPRO 2 FAIL
GOPRO 3 SILVER FAIL
GOPRO 3+ BLACK FAIL
GOPRO 4 SILVER FAIL
GOPRO 4 BLACK FAIL
Not sure how you did the test, as I test Gopro3 Black, Gopro4 Black at my hand, which are working fine with our Lightbridge, if you have any further issue, please kindly send me your email to support@dji.com
DJI-Cathy Posted at 2015-7-9 11:19
Not sure how you did the test, as I test Gopro3 Black, Gopro4 Black at my hand, which are working fi ...
The LB buyers are lying then ??? you read the forum ??? already read how many users have this problem ??? LB does not accept resolutions above 720p. update your lb and use it for 3 or 4 days with a GoPro 4 and see what happens...
The initial issue as I understand it was that the GoPro when using higher resolutions to record, would lower the HDMI out put to 480p. The LB would not accept that resolution until we changed the firmware. I have used the LB on a P2 with H3-3D gimbal and the GoPro 3 Black as well.
