sbonev
Flight distance : 3665279 ft
Switzerland
jonny007 Posted at 1-13 09:51
Ignore the clown with his outrageous language and keyboard where the key "!" always stuck. In my opinion, however, it is still not clear whether the EASA will not also declare the actual weight as MTOM (Maybe?) Also because no or hardly any manufacturer has given this value until now. If that should happen, it could be enough for DJI to release a Mini 3 WITHOUT propguards, certifying the weight of the bare drone (e.g. 240g) as take-off weight and 249g as MTOM. The scope for add-on parts would then be 10g.
well the only clown is the one that argues the facts...if you want to convince yourself you are right, go ahead. don't get the drone cause it has the mtom higher than 250. i hope you can sleep better that way. and to believe that the new mini drone will have below 250 weight and be in C1 classification, well clown is not the word I would use let's say |
