Sean-bumble-bee
Flight distance : 15997 ft
You can set the max height at anything up to 500m, the max RTH height is equal to the set max height. So, if you fly up hill you can raise both to more that 120m, been there done that.
If you lost connection then, providing you aim the controller's antennae correctly, it is quite likely you would get connection back during the climb to RTH height and or the flight home. Once you have connection you can reduce the drone's height during the flight home, been there done that. Just watch that you do not accidentally change one setting/limit whilst intentionally changing the other, been there done that too and it took a llloooonnnngggg time to get the drone down into legal airspace one I had connection back, I have those FLY limit sliders.
JUST MAKE SURE to read the manual and find out if any and what stick actions cancel an on going RTH and what phases of the RTH those stick actions affect. |
