DJI Gamora
robertmanningjr Posted at 1-19 19:44
Windows 10 Pro version 2004, OS Build 19041.746, Windows Feature Experience Pack 120.2212.551.0
Last Update: 2021-01 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4598242)
Successfully installed on 1/15/2021
Hi, please check whether this would work. Close the DJI Flight Simulator, power off the remote controller, unplug the USB cable and insert it again, turn on the remote controller and install the remote controller driver (default address: C:\ProgramFiles(x86)\DJIFlightSimulator\dji_usb_5512_64_108.exe). Launch the simulator again and check whether the issue is fixed.
If the same problem persists, please send us a photo of how you connect it to your PC and what USB ports you have tried so far. Please also link the remote to your aircraft then check whether it is working properly and with no error. |
