A couple fixes for the RS2 required.
409 4 1-18 16:05
AntDX316
Flight distance : 2982907 ft
  •   When inverted the hardware joystick controls do not invert.
  •   When inverted you have to manually select on the touchscreen menu to invert in rotation
  •   When in upright mode and screen inverted Rotation, you have to disable it on the menu for be in proper rotation
  •   When in Activetrack, then switching to camera Playback on the camera, Activetrack stays on.
  •   Coming out of Playback on the camera that is livefed to the smartphone w/ the Raveneye, the virtual joystick no longer appears.  You have to come out of Raveneye for it to be fixed as turning off and on virtual joystick or going force mobile then back to virtual joystick still doesn't make the bottom left on-screen touch control appear
1-18 16:05
BeeS View
to your first 3 points, if DJI would enable an automatic turn of screen and joystick invert between upright and underslung the usage in briefcase mode will become unusable as you constantly pass the border between upright und underslung. I have this effect quite often with the smallHD Monitor when filming in briefcase mode and the picture flips.
1-19 05:18
DJI Wanda
Hello Pro user, thank you for your feedback on the DJI RS2. We will send you feedback to our product team for the reference. Cold you please tell us the camera combination that you used? It will be helpful for us to test and improve the user experience, thanks a lot.
1-23 06:47
AntDX316
DJI Wanda Posted at 1-23 06:47
A7R4 (10 character limit)
1-23 10:52
sky_makai
Flight distance : 1331283 ft
Also when inverted... When double pressing the trigger to return to center, it spins around 180 degrees.  That's a pain.
5-13 16:47
