Flycaster
Well, first off, I would try a factory reset on the whole kit. You may have to use the "assistant" for that on your PC.
Go to a clear, calm, wide open area free from magnetic materials. and see how it behaves, and hopefully, will be corrected.
As a very last resort, you can try to "do an update", and see if that does it. I would use that as a last resort tho...
I have a Mav Gen I like you from that same era, and have never updated anything bird, controller, or batteries and all is fine.
Not hampered/nagged by the stuff DJI tossed in....My preference....
Try the resets first, and failing that, think carefully about doing an update, that may work for you......as a last resort... |
