Kindermuhaaa
Flight distance : 25128 ft
hello, i have a standard phantom 3, and an internal square 2.4ghz antenna wire is cut, the one that is black, I had put an argteck antenna kit so I recovered a square antenna in my radio, the one with the black wire and I put it in the drone in place of the original one,
do you think it will work as before?
I wonder if these square antenes in the radio and the drone are not for the radio "transmitter" and for the drone "receiver",
if this is the case it will not work
someone has done this before and can tell me if it works?
I looked on the net and it is no longer done in nine,
So have you replaced these antennas with another model that is also or more efficient?
thank you very much for your answers and your help
