Remote is charging phone
7853 10 2021-2-4
cjbridges85
Any solution for the remote charging phone issue? Just got mine the other day and just noticed today my remote died super fast. I recharged it and realized it was charging my phone when i connect it to the remote .
2021-2-4
K6CCC
Flight distance : 651683 ft
Assuming you are using an Android, no.  It's part of the android spec.  Only real solution is to make sure the phone is fairly well charged before going flying.
2021-2-4
cjbridges85
K6CCC Posted at 2-4 17:18
BLAME IT ON THE DROID HUH....THATS A SHAME...THANKS FOR RESPONDING
2021-2-4
Porktree
Flight distance : 1118323 ft
cjbridges85 Posted at 2-4 17:46
Are you mad at K6CCC for answering your question?  Or have a stuck capslock key?
2021-2-4
DJI Gamora
Hi, cjbridges85. Thanks for reaching out! We understand how you feel, however, according to the Android system AOA protocol, when an Android mobile device is communicating with other devices, it should work at a certain current. Therefore, when the remote controller is connected to an Android device it will charge the Android device at 5V/500mA. Unfortunately, this option cannot be turned off. Your kind understanding is highly appreciated.
2021-2-6
VanzPix
Flight distance : 229672 ft
This is not DJI for once lol but Android phones. Or buy an Apple and your problem will be solved
2021-2-6
Trevor OV MM
Flight distance : 4562008 ft
Remote dies super fast? How fast? I can go through 3 batteries in my mini and the remote has at least half battery left. Yes android
2021-2-6
JohnLietzke
Flight distance : 3125968 ft
USB/USB-C has a power passthrough for charging requirement.  It is a function of the USB/C protocol and can not be disabled without modifying the Port on the controller.  IOS uses Lightning which has the ability to disable charging.
2021-2-6
cjbridges85
LMAO THESE APPLE USERS...IMAGINE BEING AN APPLE USER HAVING THIS PROBLEM...JUST BUY AN ANDROID THEN DUHHHH ITS APPLES FAULT
2021-2-6
K6CCC
This has nothing to do with Apple.  Part of the Android spec requires it.  Nothing that DJI can do about it.  And I also wonder about your fast discharging.  I have gone through four Mini batteries, and the remote battery is still doing fine - having been plugged into my Android the entire time.  Now, if you started with the Android battery at a very low level, it might be an issue, but I normally have the Android at least fairly well charged to start.
2021-2-6
Huginn Kenningar
Flight distance : 49635259 ft
I didn't have any problem with it, the battery of the controller is quite large and  you can do lots of flights without recharging, even if it's charging the phone.
Charging the phone also assures you that it won't die midflight.
2021-2-6
