HGDC84
Finland
ipilotsbcglobal.net Posted at 3-16 12:32
I just bought the P2 and I have the Samsung S7 Edge. I had to order a Micro USB adapter from Amazon. I finally got the P2 to connect to my cellphone and activated it and downloaded the updates, but whenever I try out the camera connection the video on the camera is non responsive. I only see half a frame and it won't follow the gimble when I move the P2. Therefore I'm saying the Samsung S7 Edge does not work with the P2.
I'm going to revise my statement above. I did get it to work wirelessly, the picture is great in both the video and still pic mode. So as far as working with an adapter, its a no. but working wirelessly, it a yes.
Okay, thank you for your information. Will update the list accordingly.
I have to ask though: Did you manage to do the original activation process wirelessly? I had understood earlier on that it would require the physical adapter connection. It would be very interesting to find out that even the activation could be done wirelessly!
To the people checking the list: Do note that occasionally there might be phones that are moved from the non-working list to the working one and vice-versa, due to misunderstandings or information updates. If your phone doesn't seem to work when it on the Working list, check again later for possible updates on the list. Also, if you notice a phone on the Not-working list that actually does work, please inform it here.
