Front Light not able to change colors
12Next >
6496 43 2021-2-8
Gil Soler
Puerto Rico
I am not able to see the option of changing my front light color, When I Open the APP, just after the units settings, it goes to gimball options, but do not show me any LED options, Why??  I just bought it 2 days ago and did the all necessary updates..
2021-2-8
DJI Stephen
Hello there Gil Soler. Thank you for reaching out and for these information you have given. May we know what is the model of your DJI Drone for us to be able to assist you further? Thank you.
2021-2-8
Gil Soler
Puerto Rico
DJI Stephen Posted at 2-8 22:07
DJI Steven..! I appreciate your response.  I bought a Mini 2 few days ago.  My first drone.  I found out why....., when I did the software update the first time, the drone did not reboot, so it did not got updated.  I did the update again and now I am able to see the front light menu options...!!!
2021-2-9
DJI Stephen
Gil Soler Posted at 2-9 02:08
Hi there Gil Soler. Thank you for the reply and for the given information. It is great to know that everything is now working. If you have any other concerns or inquiries with your DJI Mini 2 and with DJI. Please feel free to post it here at DJI Forum. We are all here to help and support you.
2021-2-9
djiuser_7rq5VZloew16
United Arab Emirates
Hi there I bought a dji mini 2 couple of days ago. Firmware updated to the latest version both flight and dji fly app but drones front led not changing colours when select different colours it's just stays on white colour irrespective of which ever colour I select.
2021-10-11
Marsupilami
Flight distance : 587615 ft
djiuser_7rq5VZloew16 Posted at 10-11 11:53
same here - this Front-LED-problem came with the FlyApp Update 1.4.12
and the homepoint is not displayed correctly in the radar
DJI Stephen - please send this feedback to the software developers, because these problems are really embarrassing !!!
2021-10-11
djiuser_jjScVgdfr3hw
Flight distance : 104045 ft
I have the same problem with led
2021-10-14
djiuser_NjsTNXTFXuLY
Just purchased my Mini 2 and I also can't get it to change color. Just pulsing white. No response from app
2021-10-14
DenosBest
Flight distance : 309610 ft
Marsupilami Posted at 10-11 12:54
Same here... I bought mine the other day, updated all firmware and the front LED light doesn't change... stays blinking white. I've searched all through the web and couldn't find anything...
2021-10-14
ManiekWwa
Flight distance : 280026 ft
Poland
Problem with homepoint was in 1.4.12 buid 1386 but it was fixed in 1.4.12 build 1410.
Problem with LED is still not fixed.
DJI Stephen is a bot i'm afraid. I've asked "him" few days ago (after release build 1410) what about LED problem and there is still no answer.
EDIT: There is new version to download 1.4.12 (1420) maybe problem is fixed now.
EDIT2: Still not woking...good job DJI
2021-10-15
Daves Drone 555
Flight distance : 799567 ft
Hi all.
Same issue for me, have ensured ALL software, no fly zones etc are up to date as of today (20th October 2021). Tried all options but front LED stays pulsing / White
2021-10-20
djiuser_DnrF5T6kh0kH
I'm also not able to change the colour (v 1.4.12). And though I chose for example "blue" and "breathing mode", after restarting the drone the mode is again set to "deactivated". Hope this will work soon...
2021-10-21
MiniManiac
Flight distance : 1047503 ft
I never noticed the light, mainly because its facing away from me when im flying, but yes its white and it doesnt disable
but then i downgraded to 1.4.8 which gave me all the light options and did the following test
My findings
clean install of Version 210929- 1386  light runs the rainbow cycle and ignores any changes in the app
Upgrade to 211012 - 1410 same result as above
clean install of 211012 - 1410 same result as above
upgrade to 211015 - 1420 same result as above
clean install of 211015 - 1420 same result as above.
So if you want to go back to the rainbow light uninstall 1420 and install 1.4.8
I dont know how i ended up with just a white light as I cant get it to do that at all now
2021-10-21
MiniManiac Posted at 10-21 10:46
Thanks for your suggestion.
I made a workaround to handle the problem without uninstalling my app:
- installing 1.4.8 on another device
- changing the colour and theme
- go back to standard device
> it works and keeps the settings
> but 1.4.12 says still front LEDs are deactivated
Anyway, this works for me
2021-10-21
djiuser_5FNhV2MrifYv
Flight distance : 26234 ft
djiuser_DnrF5T6kh0kH Posted at 10-21 22:08
Otro mas con el problema del cambio de color en el led. A ver si lo solucionan
2021-10-22
djiuser_kxzgCEBRdQuE
Flight distance : 1008586 ft
Same can choose another color, but no change happens.
DJI Mini 2
DJI Fly App 1.4.12
Its just pointless flying if I can't change my LED to my favorite color!
2021-10-27
CBAII
Brazil
I just bought the drone and did the installs and upgrades. Lights don't work. They always remain in pulsating white. I was worried that it was just mine, but I was relieved that everyone has this problem. So now wait for DJI to fix it.
2021-10-30
djiuser_eqgpNh1HOKYn
Flight distance : 7378875 ft
djiuser_kxzgCEBRdQuE Posted at 10-27 15:32
DJI Mini 2
DJI Fly App 1.4.12
Before the update my mini 2 led eas working fine, my daughter used it ,put it to pink solid, after update its stuck on pink solid wtf,  how do you reboot drone? Maybe that will fix it, i was flying at time of update,   drone never restarted.  ?Maybe this is why.
2021-10-30
Please help
2021-10-30
CBAII Posted at 10-30 14:38
You are lucky mine is stuck pink solid lol. Before update was working fine my daughter had pink solid so now its stuck pink. I was flying during update drone never restarted maybe that's why.  How do you reboot drone
2021-10-30
Please help
2021-10-30
DJI Mini 2
DJI Fly App 1.4.12
Mini se no led lol...at all ,,,my mini 2 is stuck pink solid worked fine before upgrading.
2021-10-30
Can anyone help me before updating my mini 2 ,led was working fine, my daughter used it and set it to pink solid, now it's stuck pink solid, when I updated I was flying so drone never restarted maybe that is why, how do you reboot drone maybe this will work? Please help,  my man drone is stuck pink solid.  I'm flipping out dji help me please
2021-10-30
Hey dji help please mini 2 led is stuck pink solid. Worked fine before upgrading firmware.
2021-10-30
700 pink mini 2 ,,this sux...wtf dji.
2021-10-30
How can you retry update  for mini 2 firmware my drone never restarted maybe this is why led is stuck pink solid
2021-10-30
fansd4d86531
Mine is not working either,just solid white..$650 down the drain
2021-10-31
Roberto Hall
Hello guys,my front light wasn't working just stuck on white after latest firmware update,I just uninstalled the DJI Fly App and reinstalled it and working fine again.Hope that helps
2021-11-1
DAYTONA392
Flight distance : 131942 ft
ManiekWwa Posted at 10-15 01:52
Just uninstall the app, then reinstall 1.4.8 (1185). Everything works with that version. It's the latest stable version they released and everything works. Its what I use with no issues. Also when I uninstall, I delete the DJI directory on my phone. When I reinstall it gets recreated. That way there's no old files left behind.
2021-11-1
Roberto Hall Posted at 11-1 13:50
Thanks I tried that it did not work still stuck on   solid  Pink. I have android. But before the firmware update it worked perfectly fis worked perfectly fine everything did. None of the new features work. Like live streaming. Also I lost my signal radar in the middle of the screen that disappeared also. The new firmware update ruined my drone..
2021-11-1
DAYTONA392 Posted at 11-1 15:44
I tried that. Is still stuck on pink  Solid. Is live streaming also doesn't work. And I lost the signal radar circle in the middle of the screen that also disappeared. I do have android.. But before the phone where update everything worked perfectly the new update ruined my drone.
2021-11-1
mine is stuck on solid pink. My daughter had that color before I updated. I also lost features and all of the new features nothing works android.  Is the update ruined my drone. Is everything worked perfectly before the update..
2021-11-1
Roberto Hall
djiuser_eqgpNh1HOKYn Posted at 11-1 16:28
Ok,what I fully did is revert back to the earliest version of the firmware I could (Jan 2021 I think ) and then uninstalled and reinstalled the fly app,then checked it and it worked,reinstalled the latest firmware and it's still working,try that mate
2021-11-1
fansd4d86531 Posted at 10-31 13:41
I called DJI they told me I should buy a Apple phone it will work better..  son of a bitches..
2021-11-1
DAYTONA392
djiuser_eqgpNh1HOKYn Posted at 11-1 16:31
If you uninstalled 1.4.12, and reinstalled 1.4.8 (1185) there is no live streaming option. So if you see that in the app, you havent installed 1.4.8 (1185). Its been confirmed to work (1.4.8 1185) by many many people and it does fix the light on the front of the drone issue.
2021-11-1
EnjoyFlying
Yes, i can confirm previous versions work fine with the front led, and i have switched all the way back to 1.4.4 for the transmission stability.
follow the youtube link in this post to download any of the previous versions.
https://forum.dji.com/thread-251374-1-1.html
Have fun flying and taking awesome pics
2021-11-1
djiuser_DnrF5T6kh0kH Posted at 10-21 09:23
Android update problems,  Apple works fine
2021-11-3
DAYTONA392 Posted at 11-1 17:05
Android problems, apple is fine.
2021-11-3
Android problems, Apple is fine
2021-11-3
EnjoyFlying Posted at 11-1 18:32
How do you switch back  i just got drone today , i don't have any other versions lol. On my phone
2021-11-3
12Next >
