dennismurry08
Flight distance : 5948264 ft
S-1000, plugged in my battery and got a bigger spark than normal...the beep beep on initiation sounded like it was double...LED flashed some yellow but I had it in atti then LED went dead. Quickly changed battery, same thing. Then I started to look closer and the PMU was getting hot. Unplugged the battery. I had an extra PMU and LED so tried them and same issue. Went home, changed the positive lead on the 1000, no luck. Lightbridge seems to be ok, I get the green led on video but red on control...expected. The A2 has the red led. I ordered a new bottom board to see if it might be that but wanted to see if anyone has had or heard of a similiar problem? DJI...is it possible the A2 could have got blown or what could be causing the PMU to get hot?
