fansfe82067d
Well... I spend a lot of time (why?!) looking at people's gimbal videos and pointing out problems where they've (for instance) used FPV mode causing the horizon to be off, and general instability, or in the case of some cameras looking for gimbal firmware faults causing problems, and I wouldn't have noticed anything amiss with your example at all. Walking close to a wall or fence will always make vertical instability (4th axis) more obvious.
[Edit - in fact I'd rate your 'ninja walk' pretty highly - there's little vertical movement - perhaps a bit of side to side sway - but generally, personally I'm not seeing a problem. See whether anyone else comments differently.]
