Tuxtard
Flight distance : 9975610 ft
Serbia
Update:
Took it back to the store the next day. They refused to replace it, but instead sent it to the "official" service center. After 12 days I received the drone back with the following explanation:
Basically they've said that drone functions properly and that the yellow specs are from the flux used in the production and that it doesn't affect drone performance, so they will remove them. Here you can see results of their removal process:
They removed flux from the top of the battery compartment and metal part of the battery connector, but some is still left on the plastic part of the connector, drone body and rear legs. Also rear led indicator is now loose and is moving a bit if I touch it or tilt the drone, but it works. That tells me that they probably used heat gun or other heating procedure to remove the flux. I am still worried that the remaining flux from the connector will get loose in the summer and travel to the metal part of the connector which will result in complete power loss, but at least now that chance is slim. Other than these cosmetic issues, the drone works just fine.
This experience taught me to inspect the device right before I leave the store, which I will certainly do if I get another DJI drone. |
