Labroides
Flight distance : 9991457 ft
crash1sttime Posted at 2-28 15:03
Even my mavic without using precision landing is more accurate, it’s the same system in place, mark a home point using GPS and then fly back and land on it, it shouldn’t be out as much as 5ft, that’s as bad as my old phantom 2 that only locked 7 satellites.
As for the blades, sorry but blades being damaged ( and this is a new quad with new blades) wouldn’t affect in anyway RTH precision
Your expectations are the problem.
There's nothing wrong with your drone and nothing you can do about it.
It's performing normally.
Consumer GPS cannot give you pinpoint accuracy.
It might sometimes put you within 5 ft, sometimes it could be a little more.
And if you checked the specs from DJI, they say:
Hovering Accuracy Range
Vertical: ±0.5 m (with GPS Positioning)
Horizontal: ±1.5 m (with GPS Positioning) |
