endotherm
Flight distance : 503241 ft
- no view for the camera
- no control of the gymbal from the rc when on
- app it says gymbal disconnected
- no option to select the sd card
I'd suspect no communication with the gimbal/camera assembly. Checked the ribbon cables leading to them? Have you had a hard landing or crash?
The aircraft seems to be receiving flight controls correctly so I assume the other discrete commands coming from the remote are correct too. Flight controls like the joysticks and physical buttons can still function separately from input/output from your onscreen app. Try testing if you can tilt the camera up/down using the rotating knob on the front of the controller, and try the same using your screen to do the same thing. For confirmation, try taking a photo using the shutter button on the remote and again from the app. Let us know what happens.
