Hallo I have the global DJI solution A2+Ground Station+Z15-GH4+iOSD If i connect all the devices as suggestet by DJI (look at attached image) I can't move in any way the gimbal with my Futaba 14SG radio, connected of course via s-bus. Important thing the A2 assistant works, I can see the sliders moving but no real action on gimbal. It is alive (I can see the GH4 image on the receiver display) but no action at all as for tilt, pan, or shutter. But if I connect the Zenmuse to the Can1 channel... it works! I loose the gimbal telemetry on the display, and DJI recommend to connect it on the other channel, so I am not confident on this solution, but it works perfectly. Does anybody has some suggestion? Thank you.
