Magic Light Media
Flight distance : 3226542 ft
DJI Stephen Posted at 3-2 22:44
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. You may give a try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value (usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200) to see if the issue will still persist. Thank you.
Hi Stephen,
I have a 27 inch macbook.
What is the recommended resolution for that.
It also says it doesn't detect the screen size, so I have to manually enter 27 when it prompts. |
