Hi, My DJI died whilst flying under a bridge. it moved itself to the right instead of to the front, ignoring my commands while i was 20 meters away, also ignoring my correction (Full throttle) to the left. whilst being very close to the drone. In all other cases it did not pose a problem to fly under a bridge in an urban environment nor a narrow tunnel without gps with strong wind effects, as can be seen here. This is inconsistent behavior at best and crappy programming at worst. Pilot control should be leading at all times, especially in the atti mode it changed into and if GPS loss was such a problem, it could have defered my vector (direction+speed) from just before losing gps. The mavic before randomly took a plunge whilst stationary (reimbursed), the 2nd was losing connection within 400m range and not returning, the first suicided into a tree without my command right after takeoff. The 1st was reimbursed only after showing a video with my flight controls so they changed their conclusion that it is a compass error. but now they stick with their conclusion that the drone was controllable.
Are there any alternatives out there with similar camera quality and portability as the m2p which is not DJI?
I have a video. showing my controls at the accident, an earlier, similar accident, and cases where the mavic was functioning normally.
Attached are the flight logs of my last flight + the flight before where it did not return to home when it was supposed to but went moving further from home.
[URL unfurl="true"]https://cloud3.zoolz.com/s-iFyurjPd[/URL]
