DJI Gamora
Hi, MagnusFPV. Thanks for reaching out and posting your inquiry. The roll angle is equivalent to a roll control switch, which is actually a switch for coordinated turning.
Large Angle: To assist the aircraft to roll a larger angle when you control the roll (suitable for the first flight, used to go through woods)
Small-angle: To assist the aircraft to roll a larger angle when you control the roll(suitable for high altitude aerial photography)
Disable: The aircraft roll was controlled by the pilot (suitable for self-manipulation) has nothing to do with the angle limit. The prompt limit information is related to the M mode attitude limit.
