serval
Flight distance : 61204 ft
Hello, recently I have bought my first ever drone and did a test flight with it to get used to how everything worked. I flew a couple hundred feet away and decided to use the return to home function. Initially, it worked as expected. It turned around and went to the desired altitude to return home. However, within a couple of seconds, I lost the video signal and RC signal and the drone has crashed. Initially, I thought that due to a loss of signal it would go out of control, but I did more research and discovered that it's not supposed to just fall out of the sky in these situations. I was able to recover the flight log and discover that the last log recorded was completely normal, and showed no altitude drops whatsoever. The only conclusion I could come is that somehow the power failed and the drone just turned off midair. I had 72% battery when this happened. Fortunately I got a replacement for free, but I'm worried that due to this incident, it could happen again.
I would like to know if anyone else has had a similar experience with their Mini 2 completely shutting off midair, or I just had some bad luck.
