DJI FPV Propeller Guard & Arm Bracers
4392 7 2021-3-10
amitgv1
Flight distance : 1032493 ft
Hi,
Do you know if I can use the Propeller Guard & the Arm Bracers both together?
2021-3-10
DJI Gamora
Hi, amitgv1. Thanks for reaching out! The DJI FPV Drone Arm Bracers and the DJI FPV Propeller Guard cannot be used and installed at the same time.
2021-3-15
djiuser_dktY0MVneovU
Which provides the better protection?
2021-5-16
Duane Degn
Flight distance : 622234 ft
djiuser_dktY0MVneovU Posted at 5-16 21:35
"Which provides the better protection?"
To the drone or to people?
The arm braces are better at protecting the drone, The propeller guards are better at protecting people from the drone.
The propeller guards likely prevent propellers from being damaged from hard objects but I doubt they'll help much in a crash.
2021-5-17
Microeyee
Singapore
I think Propeller Guard is better because it saves your propeller which can crash your drone if it gets friction against any object and damage others. That guard avoid both from happening.
Arm braces comes later when you crash your drone - as in how much damage it can sustain. Here i personally think propeller guard again provide some protection not letting the drone arms directly taking the hit.
But if you are looking to include both - there are other options out there 3rd party sellers providing all in one kit that will fit together everything.
2021-9-11
Kapil Vachhani
Microeyee Posted at 9-11 19:24
Hi can you please share the link of that all in one kit .
thanks
2021-11-18
fans80fa58f5
Flight distance : 13934 ft
Kapil Vachhani Posted at 11-18 06:30
thanks
This forum won't let me post a link, but if you search Ebay for item number 403081076498 you'll see one. I haven't tried it myself, so can't vouch for the fit or quality.
2021-11-28
JSMavic2Drone
I'm going to throw my 2 cents in there. If you're going full on acro manual, then 'probably' the braces, as your chances of a crash are much higher  Whereas if you're more into flying with the sensors on, you'll probably prefer the guards, as it may save you from a branch.   That all being said, notice the 'probably' in my replies, as no one can accurately predict exactly where you're going to fly. You may be doing acro and the prop guards save you from a branch you didn't see and save the need for the braces in the first place. But its all going to depend how close you want to fly to trees.
2022-1-11
