jrholt1023
djiuser_mFZ8xrar2WuH Posted at 3-13 21:37
Once you've paired up either the motion controller or the standard fpv drone controller to the dji drone and the goggles are also already paired, use the OTG USB C Cable to connect the Goggle v2 to your iPhone DJI Fly app and update it from there.
It will update everything (Goggles/drone/battery/controllers) from the goggle which is linked from the DJI Fly app.
I tried doing that. I’m using an Apple USBC to lightening cable to connect iPhone 11 Pro fully updated running DJI Fly app to the DJI Goggles. With everything turned on, it did run updates for the Goggles but in the goggles it still says controller and drone need updated and when I connect everything DJI FLY doesn’t show an update I can choose to install on iPhone. I’ll try again. |
